1973 FJ55, F engine, stock carb (rebuilt 6 months ago)
Problem: Seems to be fuel starved under heavy load ie. going up a hill etc. Idles great.
Check List: New fuel filter, cleaned tank and lines, mech. pump is working fine, no blockage at all. Good spark, good Vac. 19.5 Hg., timing fine, valves adjusted properly, fuel in middle of sight glass at idle, fuel tank venting fine, yada yada yada.
Curve Ball: A couple weeks ago I stripped the banjo bolt fitting on top of the carb. I drilled and tapped it to 12mm 1.5 and used a non Toyota specific fuel banjo bolt. The new banjo bolt has a larger opening and no adjustment like the original bolt.
Question: Is the new banjo bolt allowing too much fuel to bypass the carb due to lack of back pressure?
Thanks for any info,
Jason
Jason
