For sale: "Glide-Thru Carver" Sandblast booth.
I'm selling my blast booth and thought I would offer it here first for Mud members who might be interested. This booth has plenty of room for all kinds of parts to fit inside as well as a shelf that folds down if you're going to blast smaller parts. For larger parts like door (or whatever) the top & sides will open to allow you to fit it in then close it around the object to keep the media inside the booth. I would normally run this at about 30 psi for glass applications, but it has a wide range to work with. I hadn't even dusted it off when I shot the photos but this thing is in almost new condition. You can use a wide range of abrasive media in this cabinet. It also has two arms with heavy rubber rollers to support large items on either side of the booth.
I'll post it here first, if there is no interest I'll move it to the main Mud forum.
Dimensions:
Overall: 36"W x 31"D x 73"H
Window: 27"W x 14"H
Comes with Dust collector
Heavy-duty 16 guage powder coated steel
ASME rated 100 pound pressure pot (foot pedal activated)
Cloth lined gloves
2 floodlight lighting inside booth
4 outlets (2 ea) mounted to booth
Extension arms with heavy rubber rollers (2 arms not shown in photos)
All hoses and nozzles
Regulator & air filter
Manual for setting up and running.
(Compressor not included)
Air requirements:
1/8" I.D. nozzle (std), 11.5 CFM @ 90 psi
3/32" I.D. nozzle: 9 CFM @ 90 psi
$1,200
Thanks,
William
Dimensions:
Window: 27"W x 14"H
Cloth lined gloves
Air requirements:
$1,200
Thanks,
William
