FS: 94 SAS 4runner *$4,500 *O*B*O**
*******LOWER PRICE!!!!! $4,500 OBO *******
Grey 94 4runner SR5. Auto, v6.
Runs great! 167k odo. Custom trans cooler added
Customized summit CAI setup
All emissions/EGR garbage removed
Cat gutted
Flowmaster muffler (all sounds great, not loud at all)
typical minor, minor oil leak from factory oil cooler location ($30 gasket replacement)
4" SAS up front, '85 yota axle, Bilstein shocks
comes with aisin and superwinch hubs
Homebrew front driveshaft
5.29's front and rear
31x10.50 BFG AT's with a ton of life left on stock enkei wheels
All-Pro front tube bumper enamel painted black
Warn M8000 winch
Rear OME HD springs w/2" spacers, OME shocks
All power windows work great!
Sunroof works great!
Rear window recently replaced due to trail breakage/carnage, does have defroster but wiring needs to be fixed for defroster to work.
Herculined part way up doors and entire rear gate.
Rear 'spoiler' removed, partially bondo'd and grey painted w/ enamel.
small hole in stock rear bumper on pass side from rust.
Small rust area in pass rear door window area, easy to fix, I think.
Extras:
CB radio w/ 6' antenna mounted
Optima redtop
custom stainless steel battery box w/ wiring and isolator, just needs to be assembled for dual battery setup!
Snatch block
30' tow strap
Needs a little work: front springs swapped side to side, steering arms adjusted to eliminate occasional wobble when hitting large-ish bump with right front wheel.
Very smooth driver, found out it rides even better with weight in the back (try 250lbs of water!) Runs great, is a blast on the trails!
Ready for some 35's and maybe a locker. Auto trans runs great, transfer case is perfect, no problems.
Recent trans fluid drain and filter replacement, recent oil changes. Spark plugs and wires replaced last year.
Interior is fairly clean for a trail rig. A few typical scratches on sides (thanks Florida trails!) but nothing bad. Oxidation spot on hood, some oxidation on roof.
a/c is ice cold and heat works well. Has a JVC Cd player and some aftermarket speakers.
$4,500 OBO Located near Tampa, FL
Wife says I need to unload it. Someone come drive this baby home!!! Or, willing to drive reasonable distance for gas.
For pics: email chimmike@gmail.com
Wife says this has to go *FAST!!!!!!* So make me a friggin offer!
Cat gutted
Warn M8000 winch
Extras:
Optima redtop
Snatch block
30' tow strap
