Frontrunner or K9 Roof rack - Anyone fitted a table?
rlynch356
Supporting Vendor
F.V. - NC
underneath?
trying to look at options but definitely want to put a table under the rack. Its super nice to have a real table when out and about.
I assume the shark fin antenna will need to be either relocated or swapped out for a std sirius xm antenna - thats fine, just need to see how its been done before. I don't personally use sat radio but might again in the future.
thanks all
Oh this is on a 2013 200 series
underneath?
thanks all
Warning:
Poopy Table Perspective to follow... ;)
I can't quite figure out a little table (Little as in 29.5 inches by 44.5 inches...or about the size of two TV trays) that's always gonna be at LEAST as dirty as the top of the truck. If taken off road...that table table up there is gonna be CRUSTY dirty every time its pulled out. Some cool ideas aren't so practical. Got jerry cans of fuel up there? Your table is right below gasoline. Got Maxtrax up there? If used, the grime and mud drips onto the table. FrontRunner wants more that $400 for this little table that most likely needs a good hose-down before use.
OK. Poopy rant over...but wow. $$$$$$!
See below...
yep - believe me i know about dirt.. you know they make wipes for that however (at least the surface of the table).. its for prep mostly as well, we never eat at the tables.
in my D90 i have a small fold down table for the rear.. comes in very handy and takes up almost no space with the fridge in there. and yep it gets really dirty with the soft top off.. but it holds my partner stove and whatever i need to make at the time.
anyway, thanks for the link to to the side accessible table - i didn't see that.. yes they are pricey. i would rather have a large table deployed off the rear of the truck for the same price (K9/national luna)
ideally i would have a tail gate table, but with the 200 rear gate the options are limited.
I often just stick a medium folding table from Costco that neatly folds the legs inside when folded in half...& even has a built in handle...then either slide it in back on the long edge or just flat over other gear. Takes up almost no space when put between suitcases or bags. Stays clean and dry, and is never buried under stuff. Works a charm and it's about $20.
Here is the Front Runner pro table. It's a very sturdy table but a little heavy. The sides also allowed the table to rattle a little on the highway when this was on my FJ. On the 200, I must of done something different because it doesn't rattle. The slides will take some of the finish off.
For the rack, I perfer the front runner over the eezi-awn, purely for the thinner width and the bolted together design.
But having used both, I like the eezi-awn table far better the front runner table, the front runner is still really good though, but a eezi-awn table won't fit undertake front runner table.
