Jim_Chow
V8_Fan
For those of you here who've repacked your front wheel bearings on your 100, how did you know what snap ring thickness to use? There are 6 thicknesses ranging from 1.8mm to 2.8mm listed in the FSM. The FSM says to select the one that keeps the clearance between the flange and snap ring < 0.008" (0.2 mm). Did you just order two of each size initially, then try each one and stick a 0.008" feeler gauge in there?
Also, how many of you reuse the dust cap and the six flange nuts? The FSM says to replace those. How is the dust cap held on, by a grease seal or an adhesive?
Anyone remember what metric bolt size to use to pull out the axle to install the snap ring. Is it 8x1.25?
