2011 200 with 212k miles. Bought used 5 years ago and the front washer fluid (and headlamp washer I just learned existed) has never worked.
Rear washer fluid works. The wiper stalk will run wipers for the appropriate time when pulled for “cleaning mode” but nothing comes out of the nozzles.
Replaced windshield a year or so after purchase. Recently did some cowl weatherstripping replacement after having water ingress in to passenger footwell. I disconnected the tubing by the driver hood hinge and tried the wipers… no fluid
Also just learned that there are headlamp washers. Would those activate when cleaning the front glass?
Are the front wipers and headlamp washers run off the same pump? With the rear working and the front wipers moving when the stalk is pulled, I’m thinking electrical issue (bad pump, front washer relay/fuse). I already have 1 replacement pump but haven’t installed it yet.
Would passenger footwell/cabin air filter area water affect washer fluid pumping. From the parts diagram, I am seeing that there is a “windshield wiper computer” under the glove box. Thoughts?
