Working on a front end refresh/rebuild (knuckles, hub, calipers, rotors, pads, etc.).
My rotors were only 1-2 mm thicker than minimum spec so I bought new from my local Toyota dealer instead of getting them turned.
My rotor part number was 43512-60040. The rotors I got are 43512-60100. Identical except for one thing...
they're missing the 2 holes for bolting on the hub. The bolts go in through the back side of the rotor and the hub is threaded to receive them.
I'm assuming I can just drill these holes into the new rotors and be done with it? Or since the wheel studs will be pressed into the hub from the back side of the rotor can I just rely on those and delete the 2 additional bolts?
Thanks
Thanks
