I have a rattle in my front end that haven't been able to isolate, but today I noticed that my front drive shaft has a lot of play. It was rebuilt recently...any suggestions why it has so much play?
the video is brief ,
but long enough to see that it appears the Excessive Free Play is coming from the front end that is attached to the
companion flange of the front axle housing / 3rd member
I can't see it in the vid but from the sound I'll guess worn splines in the shaft. My worn splines sound just like that.But just guessing.
Get both hands on there all over the parts and work it. You should be able find exactly where that movement is happening.
Thanks for the suggestions. Here is a better video of the play:
So ......
Im still a bit unsure if the Excessive Free-play is coming from the front half side ( front axle 1/2 side ) of the drive shaft or the
Rear 1/2 section ( attached to the transfer case ) ?
can u clarify that key facts point
from the 2nd video it appears u are able to lift the front 1/2 up and down ? But its still very hard to tell
it might help alot if u mount your Video Camera back a little , so the entire drive shaft can be seen on the screen all at the same time
i use blocks of wood like 2x4's and 4x4's to make like a little step tripod for my camera phone some times and it works well
or have another person shoot the video for u , to gain a " Whole " Perspective front companion flange to rear companion flange
this new wide angle view might Smoke Out then problem
I see that Ragingmatt's slip yoke is at the diff and yours is at the T-case. Not that it maters for diagnosing. I have mine mounted like yours.
When I grab the yoke and shake it like in the pic I can feel some play right where the arrow is. Maybe try that?
i wondered about that , weather it was on backwards or not ?
