I want/need front disc brakes. I can procure all the parts needed, but I can't do the work myself. Who can I pay to do it in the immediate area? And how much will the labor be, approximately? I could help if necessary. I have a stock 71.
Do you remember a while back that I talked to you about an front axle with discs? Well, I dismantled the axle and now have just the knuckles. These will be a bolt-on for your front axle.
That is probably the easiest route, and it allows you to get in there and replace all seals, bearings, seals, wiper kit, etc. The whole rebuild kit is around $100 (if you reuse the wheel bearings).
If you are thinking safety, my truck never drove better than when I finally got around to rebuilding the knuckles.
That rebuild kit is not at all hard, and if you can follow direction from you chiltons, haynes or this board, you can absolutely do it. Or, with enough beer and pizza, you can get a local cruiserhead to help you out.
The only special tools you need are a fish pull scale (about $9), a tie rod fork and a brass drift for the cone washers.
Get a big piece of cardboard to lay the stuff out,a big bucket of kerosene or parts cleaner, do one side at a time, and go to town.
I have all the parts except for the rebuild kit, pads and rotors. I really need to do this to my cruiser because I am sick of adjusting drums and the brakes keep pulling. I haven't done it before but it really doesn't seem that hard. If you are really interested and want to come check it out while I do it maybe we can work something out.
The use GM rotors and calipers. The rotor center holes need to be milled out. They're just bare knuckles. You'll have to either buy rebuild kits or reuse your old stuff if it's good enough.
Are you doing mini truck or FJ60 or something else I don't know about? Also, do you happen to have a list of parts to buy?
The knuckles don't need to be milled out. I think you need a set of mid-90's K1500 rotors, and a machine shop will have to take about 0.02" off all the way around. This is definitely the cheapest way to disc brakes that I can think of. I went to later model knuckles to run Longfields.
Someone said grind off the rivits and weld them.
Are you running stock wheels? Disk wheels (rock crawlers, etc) will fit drums, drum wheels will not fit discs.
FJ60 stock chrome spoke wheels are about $20 ea at a junkyard, rock crawlers are around $35 ea new.
You are going to be into it for $500 regardless, even if you do it yourself.
$100 rebuild kit for axle
$75-100 for a front disk axle, 79+ Toyota pickup or landcruiser
$50 ea reman calipers
Stock FJ60 vented rotors, new- $75 ea? You could turn them off the parts axle for less, but I would check new first.
Gear oil, brake fluid, new lines and hoses, you get the idea.
Poor Wally does this swap for clients often, I would think Kina (cruiserland) and several other guys fairly locally.
