Front brakes done!
Behind the bar
My brother-in-law came by today and helped me work on the brakes. He's an ASE certified something-or-other (I don't know the details of those certifications). It's great having a mentor available. He let me watch while he talked me through 1 side, then I did the other.
Took a while (7 hours including a trip to NAPA, and a long lunch break), but we:
1) Replaced the front rotors with OEM.
2) Replaced the pads (1MM!) with 100 series.
3) Flushed the brake fluid.
4) Checked rear brakes (LOTS of wear left; although I do need to adjust the e-brake)
I haven't check the Birf procedure in detail, but I suspect we were much of the way into it. :idea: :whoops:
Looks like the axle service the PO mentioned was fairly recent, but not the best. Lots of old grease in the bearings & housing (with new over old). Looks like the mechanic's primary tools were a screwdriver, a chisel, and a BFH. Seals on both sides were severely distorted by screwdriver marks (were they even working?). The axle nuts were cut up so bad, we couldn't get the socket on them -- had to use a screwdriver to get them off (used a grinder to smooth them out for reinstallation).
Question: We packed the bearings with "brake grease" on his recommendation. I wasn't comfortable with this, but let it ride because I'll be back in there in the next few months for the birfs AND I have new bearings from CDan already. Next time should I use Moly (synthetic), Lithium (synthetic), or Brake grease? :confused:
The 100 series pads fit very tightly, and we couldn't fit the shims between the calipers & pads.
Question: Is this a big deal? Can I just install them when I go back in for the birfs? Do I need to even then? :confused:
And I need a caliper rebuild kit: The gasket (is that the correct term) in front of one of the pistons was mangled and preventing the (very tight) pad from fitting. We ended up removing it.
The brake fluid had apparently never been flushed... either that or brake fluid gets nasty-brown really quickly (the master cylinder is brand-new) :doh: My bro-in-law has a cool gizmo that you attach to the bleeder plug. Little tank holds about 1 reservoir of fluid (max to min). Open bleeder valve, pump peddle 6-8 times (until tank is full), close valve, dump tank, fill reservoir, move to next bleeder. Very quick and very effective -- and doable by 1 person. :)
One of the birf procedure writeups mentioned to leave the nuts on by a few threads when you're "tapping" the tapered washers loose. VERY good idea! :idea: I forgot until 1 went flying across the garage!!!
Overall a very productive day. I'm sure many of you could have done it in an hour or two. :flipoff2: But I'm very happy: truck is working; had all the necessary parts onhand (or at NAPA); got my hands (and feet and legs and garage and ...) dirty; and I don't have to sweat about the brakes for a while! :grinpimp:
Tomorrow: Transfer case indicator sensor, CDL switch, Pin 7, and Antenna Mast (at least according to plan :) )
:cheers: :cheers: :cheers:
Hants
"And I need a caliper rebuild kit: The gasket (is that the correct term) in front of one of the pistons was mangled and preventing the (very tight) pad from fitting. We ended up removing it."
I think it's called a piston boot. It keeps grit from getting into the cylinder. Kinda good to have in place, and intact. The rebuild kit is pretty affordable, and not too hard to install. I'd do it soon.
Congrats on all the great work. Great feeling!
Leave the shims out. It will not bother it. Yes you were quite a way into an axle overhaul. Next time you will be faster because you know a lot of the route now.
Not sure what you mean by brake grease. You need to use a high quality lithium wheel bearing grease on the bearings including the knuckle bearings (I use Mobile 1 red sythetic). Then you need to use a moly-fortified grease in the birfield joint and the adjacent cavity.
Jim
Jim
Brake grease = cheap tub-o-grease from NAPA... I didn't think I should be putting it in there. The label says it is moly-fortified NLGI2 rated bearing grease.
Any problem leaving it in there until I open it back up for the birf job (month or so)?
I have full Amsoil synthetics (lithium & moly) lined up for the job.
Hants
Hants said:
Brake grease = cheap tub-o-grease from NAPA... I didn't think I should be putting it in there. The label says it is moly-fortified NLGI2 rated bearing grease.Any problem leaving it in there until I open it back up for the birf job (month or so)?Hants
It's fine like that and IIRC, that's what the factory manual calls for. I like Mobile 1 red synthetic wheel bearing grease.
