- Joined
- May 14, 2006
- Threads
- 41
- Messages
- 258
I got a front axle given to me and it's been outside for a while. It came dismantelled and pretty messy, but with knuckles and spindles etc.... I will be buying a rebuild kit,(best price/quality?) I will need to also buy axleshafts/birfs and new hubs. Most of it is standard rust on the housing etc and will be dealt with. My concern is in cleaning up the knuckle ball (chalice?). What should I use to clean it up and make sure it's still in a useable shape/condition? Also, will be beefing it up and building it as strong as I figure I'll ever need it to be, thern just swapping it into my truck. At that time, I'll do the crossover/hi-steer swap. So:
Axles-seems to be a heated discussion out there as to who or what is the better replacement for stock birfs? I will more than likely never have bigger than 35's, but only have 33's for now on my stock axle.
Seals
Bearings
Hi-steer kit w/arms
6 stud knuckle?- Is this just for really big tires? I like the idea of being that strong, but is it really a necessary upgrade?
Armor- A gussset to help strengthen the top is cheap and easy, but what else is worthwile. It doesn't have any bearing on tire size or engine power so I figure other than weight, can't go wrong beefing up everything.
Seals
Bearings
Hi-steer kit w/arms
