Free fj60 parts
Shenandoah Valley
I've got a few things that I need to clean out of the basement for free if you want to pick them up. Hope this is the right spot to post this up. All if from an 83 fj60. Fairly rust free gas tank, complete steering column, distributor, ignitor, tail-lights, wiper motor, heater blower, functional smog pump, wiring harness. I can meet you right at the end of 66 in the Shen. Valley if you are coming from that direction.
thanks, hope this helps someone.
I'll take the stuff if you still have it. I'm in Winchester
I'll PM you my number
thanks
Burl
Burl
ya beet me to it!
When we going to pick it up.
I can meet you at Shenandoah memorial hospital Wednesday.
Name the time.
Chris
Parts
I told Burl I'd meet him at his house on Wednesday and drop it all off. I will be going right by it on the way to one of my jobs.
Thanks
Brian
Brian,
Thanks again for the parts. You saved me some $$$ with the VSV and VTV. When I put in your carb cooling fan, I discovered what was wrong with mine (other than a nonexistent temperature sensor). It turns out there was a hornets nest inside the fan which must have jammed the fan causing the motor to burn out. I guess the PO must have left the truck sitting for a while. Hope this solves my hard start problem when the engine is warm.
Thanks,
Al
Thanks Brian
