Idle sounds great, and runs consistently. I searched the FAQ and think it might be one of two things:
Gunky fuel-filter
Not enough gas in the tank
The first one is obvious, and I'll check today. The second one I recalled seeing in a thread (somewhere at some point DEEP into a search
. The person said they were having fuel-starvation issues when their tank was lower than 1/3 full (or something like that). I know I have about 2 or 3 gallons in the tank right now, as I've kept it relatively empty/low during all the work without the rig running.
Does that option make any sense as to the possible cause? I don't THINK it's a vacuum issue as I can add a little throttle above idle and keep the engine running...but anything in the 2000rpm range it's starts choking/stuttering out.
I hope that makes sense. I can post some pictures if it would help. If anyone else has other thoughts on something I should check as well, I'm all ears!
Thank y'all!
Gunky fuel-filter
Thank y'all!
Thank You, Sir!
