- Location
- United States
Hello all, I have the following items from a green 99 LX470: vehicle had 170K miles.
4 compete doors (includes door cards and internals)
Dash center piece, including all switches/buttons and working climate control unit. Also have working radio. Also have complete 4 working speakers, factory amp and factory sub/box.
Center armrest/with working latches.
Center gear stick piece with AHC switches / heated seat switches
Gear stick assembly
Two rear bottom arch panels
Engine Evap/charcoal canister
Fuse Box
Inside air cover (for those who want to upgrade and use a filter)
Complete air intake system
Complete steering column including wheel
(wheel is in rough shape, but airbag is good)
A ton of inside plastic trims - mostly bottom pieces.
ECU
Good working condition Brake Booster/master assembly. (Truck drove/stopped fine)
Front headlights (not original - aftermarket Taiwan stuff. Good shape, could use a buff)
Front headlight trim surround piece
Engine fan and clutch (had 35K miles on it)
AC cooling fan
Rear view mirror
Sunroof/garage switch upper console
Alternator (has about 120k miles but fully working shape)
AC compressor (as far as I know original to vehicle so has 170K miles) - was fully working.
Starter motor - does not look original, fully working condition. Fan shroud
2 x OEM tool bags. One complete with tools. The other missing some. Also original Jack.
Antenna relay
Tailgate lexus divider/flap piece
Also have driver/passenger and second row seats. Front seats are torn and worn. Have plans to recondition these and swap out for my own unless someone makes me a good offer for them.
Illumination control panel
Speedo/cluster (I may keep this for a custom project)
Bottom steering wheel panel with all associated switches
Front Diff - again may keep unless someone really wants it…
I’m sure I’m missing a few pieces here and there but that’s most of the items… happy to send pics of items to those interested. Just pop me a PM.
Gear stick assembly
Fuse Box
ECU
AC cooling fan
Rear view mirror
Antenna relay
