And don't be too embarrassed for asking. I thought it was a great idea when I first heard about it on the LCML...
Date: Mon, 22 Dec 1997 13:21:54 -0800
Kahler, Charlie wrote:
> I am thinking of removing and flipping over my front 3rd member on my
> '74 FJ40. I figure it would help my driveline angle problem by raising
> the pinion about 4". My question(s) is; Aren't the gears cut to run
> primarily in one direction? If I flip it over, the pinion would have to
> spin the opposite direction to go forward. This is bad, right? If I take
> the 3rd member out of a REAR axle assy, and flip it over, it would be
> spinning the same direction as if it were in the rear. Problem solved
> !?!?! OK, now the next problem, if I flip the 3rd member over, would the
> pinion bearing assy get enough oil to it? BTW: I rarely go over 25mph
> in 4wd.
> Has anyone done, or attempted to do this, or am I overlooking something
> obvious? (besides the oil)
The front and rear third member are the same on most Land Cruisers (don't
know about the 80's) and clockwise is still clockwise, even when upside down
so I wouldn't worry about that. Oiling is going to be a major problem and if
you can solve it this might be a real trick way to improve drive line angles
and get that pinion off the rocks. I'm sure someone on the list will tell us
why it can't be done or it would have been done by now. If your housing is
similar to my 60 there is a slot cut on the top and bottom to allow the rig
gear to fit in and you will have to cut another set on the other side. If
this is all the modification you have to do other than the oiling please be
sure to post your results.
Cheers
Bruce
