Flap Inside Front Wheel Well -- need part number
1997 80-series. There are rubber flaps that hang from the body vertically, inside (parallel to) the front wheels/tires. Mine are ripping off. Does anyone know the part numbers for the flaps and the fasteners used to hold them on?
Thanks
Right front, 53736-60010
Left front, 53737-60010
Center, 53738-60010 x2
Left rear, 53735-60010
Right rear, vacant to clear exhaust.
Clips, 90467-07132
NOTE: top number corrected 3/3/22. two digits inverted. :doh:
Just replaced the flaps on my 94 and the only one not available was the Left Rear so flexsealrubber coated the old one. Maybe Phil Swift will put me in the next infomercial...
Right front, 56736-60010
Clips, 90467-07132
One online Toyota dealer says 53738-60010 does not fit my 97 but says to use 53738-60011 -- any idea if that is correct or what that part is?
53738-60010 goes up to March 1996. 53738-60011 goes from April 1996 to December 1997. The latter number is larger and more expensive. Either one will fit.
Correction? 53736-60010 should be front RH.
Plan B (the frugal alternative) is rubber flooring cut to size and some serrated plastic push rivets. That's what I've had for the past 15 years for several of the pieces.
Wish I knewed about the rad aftermarket flaps as they look nice. I went OEM versus homebrew as anything I design and make generally is aesthetically challenged. I did a quick Google search too and nothing popped up.
OEM lasted me 25 years before I ordered replacemens. 🤷‍♂️
I should have looked sooner, but I see that there are three separate overlapping pieces in both the front left and right wheelwell. Does each have its own part number?
Three on the side opposite the exhaust. Only the front two and the side the exhaust exits on. The front and rear sections are left and right-handed. The center section fits either side.
