- Location
- United States
Up for sale is this amazing 2000 Lexus lx470. This vehicle is a stunning 1 owner example with 224k well cared for miles. Every service the car has needed has been preformed over its life always at lexus of Fort Myers. The body is in amazing shape. The only wear/flaw is on the front bumper where it has a minor scrape. Besides that the pearl white paint looks like it just rolled off the showroom floor. Always been garage kept. The interior has aged great as well. No significant wear anywhere on the truck. The driver seat does have some very minor. wear which is expected and one of the hinges on the glove box is acting up but it still works fine. Due to this I would rate the body a strong 9/10 and the interior an 8.5/10.
Mechanically the car is in fantastic shape with no leaks or any odd sounds. Tires could use replacement soon as they were put on at around 50k miles ago and re reaching the end of their useful safe life.
The following has been done within the last 50k miles not counting routine oil changes and minor work.
180k. Valve cover gaskets,+axle $755 (not at Lexus dealer)
180k miles Front pads and rotors, oxygen sensor, timing belt kit, water pump, air filter, fuel filter $2220
181k miles new fuel pump assembly $934
182k miles-main relay $105
203k intake manifold gasket, rear pads/rotors, valve cover gaskets $1746
203k miles cooling fan/motor,oil change, air filter microfilter,brake flush, complete rack and pinion replacement, front diff fluid, rear diff fluid, transfer case fluid, spark plugs,$3385
205k miles Full A/c system replacement including evaporator,compressor, expansion tank and condenser $2448
205k replace ignition cylinder + reley $1598
206k lifetime precision battery and terminals $319
224k New 2nd key 100
There are plenty of other services but I just took a quick snapshot of what some of you may find relevant.
The car has been owned in the South all of its life and has mostly stayed down south the entire time. The underbody is fairly clean and all structural components are either rust free or just have minor surface rust. There is minor surface rust around the rear sway bar and rear differential but again nothing structural and I would consider it “rust free” Everything on the vehicle works. From the AHC suspension to the sunroof and all the other creature comforts.
The asking price is $9200.
