For Sale FJ80/FZJ80 Birfield / Axle Parts / Hub Studs / Seals / Star Washers / Gaskets
Ft Lee, VA
I had an FZJ80 for several years and I acquired a bunch of parts, especially axle service pieces, all OEM factory parts. I sold the 80 and am cleaning out the garage now. $50 for all of it, shipped. Or make me an offer on what you want, minimum purchase $20 because it's not worth my time to box it up and ship it for less than that. I just hate throwing stuff away and would prefer to see it put to good use. The birfield is a used OEM piece with 130K on it, and it has the tone ring on it. No problems or clicking from it. All parts listed below.
KOYO BEARINGS JLM104948/10 90368-49084 X 1
KOYO BEARINGS HI-CAPLM102949/10 X 1
TOYOTA BEARINGS 90366-20003 X 2
TOYOTA OIL SEAL 90311-62001 X 1
TOYOTA REAR AXLE CONE WASHERS 42323-60020 X5 (2 NEW, 3 USED)
STAR WASHERS (2 NEW, 1 USED)
3 SNAP RINGS
TOYOTA AXLE HUB NUTS 94115-71200 X 5 (2 NEW, 3 USED)
TOYOTA KNUCKLE STUDS X 2 USED
TOYOTA KNUCKLE UPGRADED STUDS 90126-_____ X 4 NEW
TOYOTA WASHER 90201-08042 NEW X 1
TOYOTA 90099-17115 SPRING X 1
TOYOTA 90201-12029 KNUCKLE STUD WASHERS X 2 NEW
TOYOTA 41343-60010 DIFFERENTIAL PIN X 2 NEW
TOYOTA 90116-08325 FRONT KNUCKLE HUB STUD X 1 NEW
TOYOTA 90311-62002 OIL SEAL X 1 NEW
TOYOTA IGNITER 89621-26010 X 1 USED FUNCTIONAL
TOYOTA 19080-66010 (90919-02209) COIL X 1 USED FUNCTIONAL
TOYOTA OEM BIRFIELD JOINT WITH TONE RING X 1 USED
FRONT COIL SPRING SPACERS 30MM LIFT X 2
IRON MAN FRONT COIL SPRING SPACER 20MM LIFT X 1
MAN-A-FRE REAR COIL SPRING SPACER / TRIM PACKER 10MM X 1
MAN-A-FRE REAR COIL SPRING SPACER / TRIP PACKER 5MM X 2
(When lifting with the OME springs you often need small adjustments left to right to get it to sit level, hence the one-offs left). 25.4mm = 1 inch.
All the pictures can be seen on this craigslist ad: FJ80/FZJ80 Birfield / Axle Parts / Hub Studs / Seals / Star Washers /
