Wanted Fj60 transmission hump inspection cover
Texas
  1. 40 Series
Good day/evening,
I'm in search of a later style Fj60 transmission tunnel cover like in the pictures below. It's gonna be the removable "inspection cover" that I will be needing for my project :)
Thanks you guys for your time and help!
shopping
shopping
there are 3 versions of the 60 trans hump cover
is the one in your pics above the one you want/need?
Yes, that is the style that I wanted :]
I think it's the later style Fj60 transmission inspection cover for 1984+ but I'm not too sure. I really need the cover that has raised portion stamped into the metal like in the pic. Thanks again
I think that is the middle year range 82-85
85+ was a 5 sided design, this one above has 4 sides
do you need the boots also?
I have a few 82-84 style like you have pictured. With boots. $112 shipped
Bottom left is the the US market FJ60 4/85-7/87 inspection cover. Not for sale. But this the one used on the FJ62 when adding a Toyota manual transmission.
I'm not in need of the boots, but, if it's the thicker Fj60 style though, I would be interested :) what is your price?
Nice! And the boots are in good condition? I may just take you up on it, will have more time tomorrow once I get off from work.
Bottom left is the the US market FJ60 4/54-7/87 inspection cover. Not for sale. But this the one used on the FJ62 when adding a Toyota manual transmission.
Thanks @Living in the Past. I've referenced a lot of your posts in previous projects and this is no different to that :) my project is to finally put the transmission tunnel, from a 3 speed transmission, onto the tub of a 1971 fj40 running a h41 transmission. I've finally dug up an old forum post that has the guy use one of these Fj60 top covers to "raise" their 3 speed style hump to fit a 5-speed transmission into a 1973 fj40. I'm using an early h41 and the transmission top plate is very similar to the 5 speed. It's 1 solid piece with a tall shifter neck. So with maybe a little bit of tweaking, it will work. I was originally going to cut up and re-weld the 3 speed tunnel but it is simply too much work for me at the moment.
