Wanted FJ60 Manual (51 Viewers)
Looking for a set of Front Mud Flaps
just removed my running boards, and need the front flaps.
looking for good condition set.
I need a transition gear
I need a transition gear to connect my 16 spline four speed to my three speed transfer case. I also need the pto gear as well. If anyone has any idea where I could get these, I would be greatful for the information. Thanks
Early landcruiser aircleaner WTB
Mudmonster44- Yes I think it will work. Do you have pics? I know the early aircleaners around 71, 72, and 73 were cannister type and had a 4 bolt support from the side. What price were you thinking?
I'll wait to see if you have pics and check SOR.com for more info.
Thanks
Aaron (riddlespokane@earthlink.net)
Re:Stock FJ40 Wheels Wanted
I have wheels and hubcaps. I can send pics of the them. The wheels have surface rust and are gray. You can have them for $150 plus shipping. Let me know. Tim
Re:Early landcruiser aircleaner WTB
I have some 73 fj55 parts in the shed. I'll look this morning and l'll send pics if I have 1.
that would be for a 1 barrel carb, 68+ had a 2 barrel and the part that goes over the carb is smaller(on 66) so it will not fit :(
[quote author=MUDMONSTER44 link=board=6;threadid=9923;start=msg88056#msg88056 date=1073702735]
i have an air cleaner out of a 66 will it work
[/quote]
Aaron, I've got one from a '71 F engine. You'll likely want to modify what ever one you get as it looks like it draws from the engine compartment. There is NO means to attach as hose to the intake without cutting off the belled intake first. How much clearance do you have on the drivers side as this sits down quite low on that side. It MAY interfere with smog pumps and/or hoses or other stuff on that side of the engine. If you're interested I'll compare it to the '2/76 2F that's coming out of the FJ55 today and see exactly what might be in the way.
Re:I need a transition gear
cruiserparts.net $75 + shipping, I got one last fall brand new from them. You'll need the bearing as well for the end of the output shaft.
Anyone have a Rack? :)
Don, I have a custom built rack for a FJ40 I need to sell. I am in the Hampton Roads area (Poquoson). It has mounts for a Hi-Lift Jack, Shovel, and Axe. It does need one of the mounts welded back on, due to snagging a tree :doh:
Steven
I'd like to see them, Tim.
Message sent.
Thanks
Roger
Thanks- I am concerned that the stuff I added over on the DS may interfere with the aircleaner from the F engine. I added a rather large PS cooler line from a Ford van on that side. Does your aircleaner include a bracket that bolts the cannister to the cruiser itself? Also do you think this aircleaner would fit a rochester carb?
FYI- I eventually want to add a snorkel or fording system as my family has property in a remote area near Canada that requires two water crossings in spring. Without the cruiser setup this waY I doubt this area would be accessible.
I've got a set off my '79 that will be available shortly, currently located in Oak Harbor, I put them on my friend's rig to move it around until his shop is done, pretty good shape, a little surface rust, but better than most I've seen.
Make me an offer, or do you have some others you'd like to trade?
Mikey
Stock FJ40 Radio wanted....
Hello,
I am looking for a stock FJ40 Radio,,,,,79 or newer..
thx
80 series diecast model WTB
I have a Silver w/red over fenders 80, identical to the green one above you can buy buy....paypal
Mike,
Well I plan on selling these (5) wheels hubcaps and tires, but not until I've got the stock ones ready to go on. The tires are 31"x 10.5 x 15's Bigfoot A/T with 75% of the tread left on them. The wheels are 8" wide with 3.25" backspacing chromed steel with chrome moon hubcaps Where are you located.
Roger
Wanted FJ60 Rear Springs 2 sets
I would like to get 4 rear FJ60/62 rear springs for a SOA on my FJ40. I am located in CT and would perfer to be closer than farther away so i can pickup but no matter let me know if you have a set. I have a few things to trade, FJ40 axle parts, mini truck axle parts, w-56 tranny and transfer case, toyota IFS rear axle complete brake drum to brake drum, rear IFS springs, IFS p/s box, and EFI parts for EFI conversion on a 22RE, set of mini truck fenders and flares,
Stew
WTB FULL roll cage for my 78FJ40
Were are you located? I have a manafree cage with the front cage kit. I can take some picutes. this would bolt through the body. Let me know were you live. If you are within driving distance to CT we can work something out. i am gettin tubed out this winter so no need it:) how about 200.00 and we can figure out delivery Email or PM me
Stew
stubieone@hotmail.com
late model hard top, door and fender wanted
A buddy layed his 40 on it;s side, 400+ horsepower, Detroit locker and newbie driver......thats what ya get, lasted 2 months longer than I thought it would :D
Prefer within resonable driving distance from WA State, so Oregon or whatever, or if someone gots the stuff and doesn't mind shiping.
he needs a new hard top, with vent window(so 79+ I think, his was a 82 top on a early tub)
Needs passanger side door, 75+ (his were 82)
and a passanger side fender, don't think it matters the year.
Lemme know what ya got and what ya want for it, I'll pass it on.
John H
