Wanted FJ60 Manual (9 Viewers)
I have one off a 40 that I don't need any more. Are the mounts enough similar? I can post a picture if you want. Luke
71 FJ40 front turn signal & gas cap
Looking for a front right turn signal for my 12/71 FJ40.
Looking for a gas cap as well.
Thanks!
thanks
I called them ~ sent one out today not bad at 45.00 - the spline count was the hardest thing, but if it is the wrong part they will trade it out for the right one. Thanks.. Ray
Crossmember for H55f?
Need a crossmember for H55f conversion in a 76 FJ 40. The closer to Florida the better. Trying to not re-engineer the egg.
Thanks
the H55F was never sold in the US, not sure if one from a Canadian bj42 would work. Also you might want to give Spector a call, Marv hooked me up with my H55 top plate from a AUssie bj42.
Warn M8000 parts
I need solenoids for a Warn M8000. Maybe other winch model solenoids will cross.
Part # 28396
Thought someone might have an old used one laying around, thanks.
PM or email me.
Wanted Weber 32/36 DGAV
Im looking for a weber progressive carb for my fj60 at a resonable price.I can rebuild it so as long as its complete the condition isnt that important.Thanks
New one on Ebay right now...
Not affiliated, blah blah blah...just noticed it tonight....
My friend is selling his project vehicle(not enough time or money) and he has a aqualu aluminum tub but it is extended 20 inches longer. If you are interested fire me a mail and you can get in contact with him.
eternal2@telus.net
We are in Kelowna BC by the way.
x member under a BJ42 with a H55f is just like the one that holds up a h42 in a 80-84 60 series. I'd use one of those and adjust it to suit the width of the frame rails where you happen to be mounting it. It'll look and act like it was factory.
Good luck
If you mean the parts over the front fenders and under the edge of the hood then yes they are aprons. I have a few pairs from various years. What year are you looking for?
Nick Jennings
Gotta tell me where to send this gas cap to in OH. Freebie for at least not being on the left coast.
Good karma is a Good thing.
Oh yea, I need to inspect your wiring harness. For real, Mines fawked up.
Good luck
Not EXACTLY the same but damn close!! I, as well as "jzilla" swapped H55's into our '81 and '82 BJ60's and the crossmember for the 4 speed didn't give the front shaft quite enough clearance. You could probably fix it with a BFH if you needed to.
I think so but I'm not 100% sure. I did a search and someone posted up that the 2f engines had the alt mounted on the p/s. P/O of mine threw a 2f in my 72 but kept the alt/air/carb from the original f so I need to change it to fit a power steering pump. I've gotten a couple replies from people here with brackets so if you want 1 I can forward their pm's to you. Let me know
I kept some brackets and such when I pulled my 2F ('76 FJ40). What does it look like? I can look for it if you want.
Wanted: Cummins 4BT Engine
I'm looking for a Cummins 4BT motor in good condition. I do not want a "rebuilder"...
I'm also looking for any of the following tranny's:
NV4500
SM420
SM465
I have a fully rebuilt 2F motor for sale, and would be willing to work a trade if someone was interested.
Thanks
JR
Please email me:
jon.rutherford@gmail.com :bounce:
Also, I'm located in the Boston MAss area....
