Wanted FJ60 Manual
Need a couple of Pig parts
I need a glove box door, preferably in decent shape. I also need the aluminum door sill plates for all 4 doors. Thanks, Hodag
you can still buy them from toyota. arm's about $60 iirc, and any $8 truck store mirror will bolt on.
80-series OME caster correction bushings
Need two Old Man Emu caster correction bushings for the front lower control arms for an 80-series. Only need two but in good, useable conditon. If you have them and just never installed them or installed them and then took them - I need two. Thanks in advance.
Mike R.
I have a set of 5 FJ62 wheels, chrome, in good shape. Have tires on them as well if you want them.
Let me know,
Located in Utah.
Russ
front bumper 5211160913
left 5210360200
right 5210260200
quarter sidemold 75606-60020D0
Drivers side rear door
Hook from the hood
My paint codes are 1b1 and LC43
Thanks Frank(SJ), Doug, and Jeff for helping out.
Frank (Speedy)
Thanks for all the replies! Theyre actually for a buddy doing a soa on his.
If he didnt scrounge a pair yet, I will definitely PM!.
fj45LV rear springs are the same as fj45LBP rears.....and I "think" the 45 short beds, so that might give you some more choices.
nuclearlemon said:
i have no friggin clue what you're talking about, but is it a weatherpack connector? metripack connector? got any pics?
Here is a pic of a DRAC module (Digital Ratio Adapter Controller)
usually found on GM trucks, 89-94 s10s astrovans, and 90-95 full size trucks. I need the connectors and pigtails to one. I have the module already and plan to open up and modify to read the tire size and gear ratio I am running.
someone on the pirate board posted a link to a company in Maryland that made seatbelts very similar to the early ones in the FJ45s. they can be had in the red webbing, with the chrome buckles and had the avaitor style end clips, which are the ones tht clip on.
Thanks, I'll see if I can find it.
A 77 FJ40 has the black frame, dark grey short jump seat with out the fold down leg. The rear seat belts should be the darker grey color, but the lighter grey ones from the 79 and later years will work just fine also, they just won't match the fronts if they are still stock.
I think I have a set if Mark dosen't.
Josh
I have two 4spd trans and t-case combos for sale. I don't have any experience with either one, they came out of parts trucks that I didn't own. $300 for one of the combos.
I'm in Virginia.
Josh
Is the shifter knob the same as for a FJ40 4 spd t-case, seems like it would. If so I think I have one.
Josh
Paul_A said:
OK, shipping to 80013 is about $7.00, so if you want the shift lever, rod, pivot arm and gate let's call it $30.00. You will need to supply a few washers, a cotter pin and a shift knob. I am not sure if you will need the 4 speed t-case front engagement fork or if the old one will do, but I got that if you find you need it, too. Let me know.
When mounting a 3 speed case to a four speed tranny the front extension housing fork shaft is required (it's about 1 1/2" longer than the 3 speed one).
PTO Winch
I'm looking for a pto driven winch. I have the pto that mounts to the transmission. Just need a winch and a shaft if possible, if not, I can probably have a shaft made. Something around 8000 lbs. I live in Savannah. The closer the better.
Thanks
