Wanted FJ60 Manual (21 Viewers)
Re: running boards
Ben, I have a good set that I took off my 96. Where are you located?
Carl
Go to the web site listed below. Do a member search for a guy named Robzuk. He is located in Maryland and has a lot of samurais. If you need any smaller parts let me know. I have a parts vehicle with a few parts. Also have 2 running samurais for sale if you know anyone interested. One is spoa tin top with stock drive train. Other is soft top, spoa, 4.16 transfer case, locked rear, weber carb, header.
www.zuwharrie.com
1FZ Block
I have a short block that will need the crank turned. I am in the Dallas area and could meet you somewhere with it. Can e-mail pics also. Make offer.
I need it out of garage.
Don
FJ55 PS front fender
If anyone has an idea of where to find some steel I'd appreciate it. If I have to go fiberglass from SOR, I'll buy two so they're matched... but I'd really rather find a stock replacement.
Thanks,
J.Anderson
Left Coast
Wanted... Tail light brackets for a '68 FJ40
Hello... I'm needing the rear tail light brackets for a '68. THese are not the "large style" for '69 on up. Thanks!
WANTED....24 volt winch
I'm looking for a 24v winch with 8k pull weight or more, new or used. (432)426-2791
Thanks,
Colby
Hey Colby, you can get creative with a 8274 Warn winch and make it 24 volt.
Maybe Sheldon from G&S Cruisers is watching, I think he has performed this job or maybe Greg?
Did you get a turbo on that BJ0?
Rob
Anyone have a broken Hella Rally 3000 light??
I'd like to put a third Hella lamp on the 80 for some long distance running we'll be doing tis winter. I already have the Euro lense/reflector and just need a housing. Since its usually the broken lense that ends a light's life, I'm guessing someone will have a 3000 housing. Any will do as they're identical - fog/pencil/euro, etc.
THanks!
DougM
Wanted-Used Conferr Aux Gas Tank, Still
I'm still looking for a conferr aux tank. 4wheel parts emailed me and said the tank I ordered is discontioned. Help! By the way, for a fj40. Thanks, Pete
Doug--if you don't find one go with lightforce--I used to run the Hellas--the lightforce blow them away--they are neat becuase you can focus them like a maglite and put different color filters for fog, snow, etc. And best of all the U.S. distribution is in Idaho :)
You can buy the 240 with the gortex individual.....
I've heard nothing but good about the Lightforce, but I've already got the Hella Eurobeam lamp ($). Just need the housing. In addition, this will go between two identical Hella lamps, and I'm kind of a style hound for consistency (snicker - not).
DougM
Wtb : Tires!!!!
I hope you guys canhelp me out. I am looking for some used tires for my 82 FJ60. I'm not picky on the size and make. Preferably an AT, LT or even an MT tire. I like to be larger than the existing P235/75/15's, white walls that came on the truck. Some on the East Coast, especially around Virginia would be fantastic.
Thanks,
Chris
Hey Colby, Sheldon has one off a HJ61.
Hit me off line or maybe Sheldon will PM you.
Paging Sheldon........................
I know a guy with 33x12.50 procomp AT's. I'll let you know on Monday.
He's in Lower Michigan. near Detroit.
