Wanted FJ60 Manual
Wardens Adapter for 1970 FJ40
Yeah I heard the same rumor too. and i need the same
adapter for my 70 pig. I guess we are both f***ed then
Huh?
JimK
I agree though the one they sold was billet aluminum. But
it seems that steel could work as well. I was looking at a
friends mount last nite and all it is a plate with a tube in
the firewall and another plate. Should be easy enough to
weld the same with steel dont you think?
JimK
The shop closed down but I believe that he still sells parts off his web site, I am not positive though.
Re:Wardens Adapter for 1970 FJ40
I don't know; I checked the site, emailed; called but the number was disconnected. If I could get pics of it I can have them made. Measurements, pics, and all parts that are needed with it. I'll see what I can do.
TommyIV@cox.net
If there's enough interest in them I can definitely get them done.
80 series air filter container, intake stuff
Looking for an air filter container/housing for an 80 series.. preferably 93-97. Anyone parting out an 80 and want to sell this? Specifically I'd like the intake that connects to the fender (or snorkel), the big bucket w/ lid, and the tuna can. Also whatever other hoses you feel like parting with, don't really need the airflow sensor but will take it if it's easier, basically anything that has to do with air intake and the filter housing would be helpful. thanks.. PM away.
80 series front mudflaps
Subject line pretty much says it all. Anyone have any in any condition? Thanks in advance.
Mike R.
Riverside, CA
same boat as you guys...but i could probably spring for a knockoff if the price was right. steel, aluminium...i dont think it honestly matters...it is just a spacer...right?
75 - 76 2f Carb
Looking for a 75 - 76 2f carb in decent shape along with the air filter set up. I need to get rid of my crappy weber carb and go back to the original. Thanks.
Travis
75 - 76 2f Carb
Will one off a 74 f do the trick, I have a ccot rebuild kit for it. I would think it would work, it's a two barrel. Send me a pm if your interested. Thanks
75 - 76 2f Carb
You also might want to consider taking your cruiser to somebody who knows how to set up carbs. My buddy had the same problem with his holley and was just about ready to swap to fuel injection, and fifty dollars later his rig performed great, and was glad to have taken my advice. Alot of times it float problems. It also depends on how old your weber is. Webers have been used on many vechiles. But you also have to keep in mind, what are you asking your cruiser to do. If its steep hill climbs, your going to have that problem with any carb if its not set up right. With all the stuff thats available for the holleys, I think that would be your best bet. Hope this helps.
75 - 76 2f Carb
Screw webers, i've had 'em on my 78 fj40 and now my 76 fj40, they are s***. They run too rich, they only want 3psi of fuel pressure and i've ran the regulator and it just gets clogged. The stock aisin carb makes the 2f perform the best and I will get some mpg back as well, and they do good off roading.
75+ turn signal bases
Just need a set of base that mount the turn signals
to the flat part of the fender on a 55. lenses and
housing not important. You can even keep whats above
the base if you like 8)
thanks
JimK
75 - 76 2f Carb
[quote author=markdud link=board=6;threadid=14069;start=msg130936#msg130936 date=1080842125]
I have a carb and air cleaner assembly off of an 84FJ60. Email me at markdud@comcast.net and I can send pictures.
Mark
[/quote]
Fj60's have a different set up.
Want to Trade
I would like to trade a Warn 8274, older style but still works great. Has 100' of 5/16 cable and a hause fairlead. No remote. For a low profile warn or ramsey 8000#
