Wanted FJ60 Manual (17 Viewers)
Early brake master
I have a 63 fj40, I need to replace the brake master. I just want a good working (no leak) stock master cylinder.
Some one must have one leftover after upgrading to power brakes.
Wanted- Rebuilt Low Mileage F Motor
Does anybody have a low mileage rebuilt f motor they want to part with? I live in pa, but will pay to ship it, if the price is right. But can pick it up, if its close. My motor needs a rebuild and if somebody has one, I can't see spending the time and effort rebuilding the one I have. Feel free to drop me a email. Thanks, Pete
wtb: tubing bender
just an option for a new unit. I called JD2 on thier model 3 and got a 25% discount on the whole order if I purchased at least 6 benders. So far I have 3 people lined up.
Trent Taylor
Orem Utah 84097
Re:Early brake master
It's brakes man...buy a new one...it is not just your life...
WTB Spring hangers / used 4" lift springs
I am looking for some decent spring hangers. OEM, greasable or not, does not matter. Need two but would take 4 if the price is right.
Also need 4" lift springs. front and back. anything but Hell Creek would be fine.
Let me know what you have. and a price, Trade for anything.
Application is for a 1970 FJ 40.
Thanks
Re:WTB Spring hangers / used 4" lift springs
if you were closer i might have to take a few pieces from you, LOL
SOA and be done with it, mine hasnt finish settling yet i am with in an 1" of a 4" lifted buddies fj40. NO cut and turn.
spring hangers? you mean shackles? greasable shackles.
Re:wanted fj40
Why no odd yrs? just curious as i have never heard that before.
rattle free, well you are looking to purchase a over 95% steel vehicle.
you might be able to get both from BTB, they had one done for a customer that had all nice interior i think leather, and sound insulation, and other crap in it, but i believe it was like $55,000 or more.
windshield frame
I am in desparate need of a rust free windshield frame [75 or newer, wipers on bottom] in good condition. Will pay shipping and reasonable price. I am located in Erie, Pa. Thanks, Shad.
Early brake master
I've got one off of my 70 pig. It's yours for shipping and a :beer:. Here's a pic with the master in it...
It worked when I upgraded to power booster and discs. But if you've got it out, rebuilding is always a good idea. (if you can even get a rebuild kit)
All I remember was the crappy braking. Pump, pump, pump, pump..... But then again, that was with drums all around too. Where are you located?
Zipp.
Wanted parts for 93 FZJ80
Hi,
Just bought a 93 FZJ80. I am looking for a driver side front bumper end, frint bumper chrome molding and driver's side rear mud guard.
Thanks,
Alex
85 BJ70
83 FZJ80
Need Adapter
I need the following Advance Adapter part:
# 50-0211
Adapter for GM NV4500/TOY L/C 10SP SHORT STYLE
Ed Gilbert - TLCA #5659, So. Cal. TLCA, Cal4WD
1977(reg. as 1962) FJ40 w/5.7L Vortec
Alta Loma, CA (50 miles w/LA)
Power Steering Bearing
This part can be bought at your local bearing shop for about $20.00. Its called a pillow block, you'll need one with a 3/4" hole to fit over the 19mm cruiser steering shaft. You'll have to sand/grind a little off the cruiser shaft to make it fit. You could probaly even get one from your local tractor supply if you don't have a bearing shop close, so save your money and buy one local.
The other thing that this guy does not tell you is that you will need to enlongate the holes in the bearing, if you are going to use this style...
I do not have the part number, but there is a bearing that I have at the shop that fits into the Toyota column, between the five hole base mount and the four bolt part of the column base.
This bearing is only a couple dollars, and can be procured pretty easily at any bearing house.
I will get the number today when I get out to the shop, and PM you with it...
-Steve
I guess you would also call them Spring Pins. their on the other end of the spring. not the shackles. But if you have some shackles I need them too, would like 1.5 inch over stock..
For curiousity. How did you do the SOA without cutting and turning the front axle? ??? that may be a viable consideration for me. as I am putting this back on the road soon.
Please let me know. or send me some pics.
Thanks
Lift for a FJ-55
Looking for a set of add-a-leafs or springs that will
work on my pig its a 1970
thx
Still need one guys. Thanks, Pete
