Wanted Fj60 heater pipes
USA
  1. 60 Series
Array
Looking for fj60 heater pipes same as the pic below
Used in goood condition is fine
Keeping or deleting rear heater ?
Deleting it
if your deleting your FJ60 Rear Heater ?
then the below new Made in Japan Spec. part is a solid starting point ....
it takes the larger size' spec. 16mm heater hose coolant flow from the cylinder head directly to the heater control valve like you see below ....
it Towers over all
2F / 2F valve covers and F1.5 's also ....
i have many other OEM Japan Spec. parts Coolant Fitting & Plumbing solutions as well .....
Factory Fit Form , & Function :wrench: :wrench: :wrench: :wrench: :wrench: :wrench:
