So I decided to hit a rather long mtn trail today on the way home from camping, its called squaw peak trail, about 20 miles of pretty rocky, rough trail. Goes way high up in the mtns east of provo in utah. I was alone but I did pass a few people along the way.
I had made it a little over halfway and was on the decent of the trail when all the sudden my cd player shuts off and I hear the blower fan cut out, then lots of smoke! I shut the truck off immediately and ripped the deck out of the dash. Smoke was pouring out of it and I disconnected it, it was also pretty damn hot so i hucked it out the window in a bit of a panic haha.
A little background before I go on, The cd player has been on the fritz since I have owned it, it shuts off randomly sometimes, shows and error code other times. One of the previous owners put it in and there is a weird speaker set up in the rear with 2 speaker boxes and one has an amp attached to the bottom. Also the fan wasn't working when I got the truck and since it has been colder I did some research and found that the fan relay thing is really a breaker so I reset it last week. This was the first time I had used the fan/heat for a prolonged amount of time.
Anyways my first thought was the combo of the strange amp set up and using the fan for the first time. I had disconnected the amp and the stereo completely and decided to start the truck, no luck from the starter so since I was pointed downhill I just bump started it. Fired right up, but none of my electric gadges were working, except the tach (2h swap) which runs off the alternator and is a separate gauge on the dash, but maybe after about 5 seconds I started to notice smoke in the tach gauge!! filling it up so again I turned every thing off. Thought it might be a short on the tach wire and I popped the hood.
The battery was boiling, I could hear it and could see smoke coming from it. I disconnected all the hot side wires let it sit and let my self ponder my situation, 10 miles in the mtns with not many people around and one more up hill section to go before I could get back to civilization... The 2h has a mechanical shut off so I was in luck because I also was pointing down hill. I pop started it again and continued on my way. I made it back the main roads and then even back home(another 40miles on the highway) I know this was a bit stupid considering I had no lights whatsoever on the truck but I wasn't about to leave it some where and let it get cold and not be even able to pop start since I would need the glow plugs. But I made it!
Anyways do you guys have any suggestions or pointers? I am sure it has something to do with the crazy wiring on the speakers/amp, but to kill everything? and the smoke in the tach? I checked most of the fuses and they were fine, even the one on the amp. I am going to really dig into it tomorrow but thought I would try to get some insight ahead of time.
