Second. Mark, can't even beat you west coasters to the punch in the morning.
No jeeps here! Thanks for the info I will test after work today.With the distributor cap off, apply vacuum to each of the advancer ports. If the plate the advancer is attached to moves, the advancer works.
If you don't have a vacuum pump, you can just pull vacuum from another rig to use. The dizzy won't know the difference...unless it's a jeep!
Tested both ports and advance works at is should.With the distributor cap off, apply vacuum to each of the advancer ports. If the plate the advancer is attached to moves, the advancer works.
