HZJ60 Guy said:Hey G, you forgot to menion the drawback of the weight. How much does that thing weigh?
TB
paulj said:HZ60Guy;
Not to jump in front of RR, but the research I've found list the 6AT (Onan) specs as 120 hp @3,600.
Torgue is 220 @2,000
Your options are endless. As far as I understand it, Cummins motors (4BT, 6AT, 6BT are the only ones I researched) share the same bolt pattern as the GM. Although, I think it is slightly rotated a few degrees. I would have to dig through my notes to find out how much and which direction. You could run any GM transmission or run an adaptor and Toyota tranny.HZJ60 Guy said:What transmissions bolt up to the 6AT?
TB
Grease Cruiser said:Your options are endless. As far as I understand it, Cummins motors (4BT, 6AT, 6BT are the only ones I researched) share the same bolt pattern as the GM. Although, I think it is slightly rotated a few degrees. I would have to dig through my notes to find out how much and which direction. You could run any GM transmission or run an adaptor and Toyota tranny.
My 4BT came with a Turbo 400. I opted for the NV4500 route. IMO you would want an overdrive tranny with these motors. Or taller tires, different axle gearing, or combination of all 3.
ridgerunner said:Stock 465 bellhousing to a Ranger III overdrive.
Glad you're okay!![]()
browndog said:A few more questions:
1. is there any way to get either of the chevy motors in without modifying the heating ducts or floorboard?
Thanks
2. Can any of you guys with either 6AT or 4BT rigs send me some pics of your rigs so I can see how tall the lift looks?
Thanks
