fj55 oem hub caps
Probably not. The fronts have openings for the hubs. The rear hubcaps are solid. I don't know if the openings in the fronts would be large enough to clear the full floater.
Yes but only just. I've got a HZJ75 FF rear on my Fj55 (which I think uses the same hubs as the 55's) and I can fit the factory rims with the solid hubcaps on however I whacked the hubcap on at a slight angle and noticed it left 2 small impressions from the axle studs....but it went on!
So push it on straight and you should get away with it!
