- Location
- United States
See other post for the story of the drive from salt lake to Colorado. I am glad I got to do this drive.
The water pump is fixed and she is on the road again.
So here are pictures of the body, the holes and rust in the floorpan. What shall I do? I am not into a garage queen, I want to be able to ride her through the bushes and not worry about a scratch in the paint. I also like this rusted wrinkled look. Here is my list.
Outside
I would cut out all the rust from the floorpan and the wheel wells and weld in new metal pieces to get it all sealed up again. Then also weld in more metal where needed to keep mud and dirt and moisture from getting stuck in nooks and crannies. Treat this new and the old metal with a rust preventer or a good sealer. So the bottom of the truck is all closed and no air from below gets into the cab. It is -40 here in January and I will be drinving in full snow storms.
I will also need to do something about door seals, any recommendations for seals?
A new front window, it is cracked
May be add a mirror on the right and replace the one on the left, any sources for 45LV mirrors?
Add some more exhaust pipe and or exhaust elements to lower emissions/noise.
With all this to do I think I'd be better off taking the frame off the body so it is easier to work on, is that a lot of work / time? Looks like you could just unbolt and lift is off. But I have never done it before any snags to expect?
Inside
I plan to wirewheel the paint off, re-paint.
re upholster the benches
what should I do for the insides of the new floorpan?
I'll make plywood door panels and use 2inch tongue and groove aspen or pine slats for the roof. That'll get it a nice woodsy look inside.
The doors need to be adjusted some more to get a better seal once new seals are installed.
weld attachment points for seat belts, I'd like to have three point belts but door pillar is not very strong. Any suggestions?
If anyone sees more that I should be doing and has any ideas please let me know. I am open to suggestions on what and how to do it.
Outside
Inside
