- Thread starter
- #41
KT40,
Nice rigs! I always like to spend time discussing what everyone is doing with their FJ issues. That is why I hang out here and have learned so much from all of you. Your 45 looks like it has a lot of potential and a SLIDING BACK WINDOW
. Very nice start. Are you going stock or modified with your restoration?
esh,
I did a little internet research, the 1904 is a 795 CFM and I could only find reconditioned ones ($480.00). I only looked for a few minutes so there could be new ones still available that didn't Goggle up. The carb that I was looking at was the 1825 which is 650 CFM ($330.00). It is suppose to be Edelbrock's gift to off-roading. I have seen mixed reviews on this and the Holly off road carb and the Edelbrock sounds easier to get setup. I "think" my motor is a 350 with a 4 bolt main and it has the low flow "smog" heads on it. When I pulled the pan I did not know that the crank numbers were so important so I did not write them down. Sure glad I used one of those fancy rubber oil pan gaskets that can be used over and over again because this will be the third time I have pulled the pan off. So, I need to pull the pan one more time to verify if it is a "corvette" 350 or 327. I was told it was a Corvette 327 when I bought the truck, but you know how those stories go. The casting numbers show it going either way so the crank is the only verification that I can find that will tell me for sure. The block is one of the high tin blocks so that is a good thing. I plan on putting better heads and a set of headers on it some time in the future so I want to make sure that the intake and carb will be up to it. I don't like buying car parts that I have to get rid of later because I didn’t look at the big picture. So hopefully a 650 CFM will give me enough fuel. Any thoughts? Thanks for your suggestions.
Rockcod,
I did a search for Orange Curtain, CA and had a little trouble finding it.
I guess that you are just behind there?
I look forward to you coming by and talking Toyota's with me.
Cheers,
Jim
esh,
Rockcod,
I guess that you are just behind there? Cheers,
Jim
Lots of work, so its time to stop talkng about it and get-r-done .
