FJ40 Rock Buggy F/S Current location - Price, UT
Propane powered Chevy small block 400
SM 420 "Granny gear" 4spd transmission with a 7:1 first gear
Dana 300 transfer case with Currie twin stick
98:1 overall low range
High pinion Dana 44 front diff with Detroit Locker, 5.13:1 gears, new Superior Axle & Gear chrome moly shafts with chrome moly CTM u-joints!
High pinion Dana 60 rear diff with Detroit Locker, 5.13:1 gears, 35 spline Dutchman axles, new ring & pinion on 12/1/03!
1/4 elliptic custom suspension in rear
Custom built tube chassis on stock FJ40 frame by S&N Fab
40" Prototype BF Goodrich Krawler T/A KX tires!
17x8 Allied 32 bolt beadlocks!
AGR Rock Ram hydraulic steering
High Angle Driveline driveshafts
New Warn 9.5 ti Thermometric winch!
Simpson racing seat belts
Disc brakes front and rear
Flowmaster exhaust
Griffin aluminum radiator
Exide Orbital gel cell battery
NEW Premiere Power Welder will be included if you pick up in Utah. *
* The rig is currently sitting at a Dodge dealership in Utah, where my truck is being repaired. If you pick the vehicle up there, you get to keep the welder. If I have to bring the rig home to California, I'm removing the welder.
Vehicle Condition
This rig is NOT a show winner! It is well used, and has the dents and scratches to prove it! If you want a sissy pretty boy rig, this rig is not for you. If you want a rig that can handle any trail in the country, then this IS the rig for you! The following pictures were taken in Moab, UT at the Easter Jeep Safari two weeks ago. You can see more photos here.
The rig has a bent front leaf spring that will need to be replaced eventually (it still works). It also has a leaky power steering reservoir (I have a brand new one from GM that I will include for free) and wore out heim joints in the rear suspension (they still work, but are very loose and rattle). For a couple of hundered bucks for new springs and heims, you'll have a 100% awesome rig.
I was asking $7500 for the rig, but I placed it on Ebay today for a starting bid of 7k with no reserve.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2476210115
