Do diesels have chokes?
Maybe an idle control?
original post says it's in an fj40...not bj![]()
nuclearlemon;...not bj;)[/QUOTE said:I love BJ's![]()
Thanks, according to the BJ42 owner's manual it's the choke button (although the "normal" postion of mine is "out," and it doesn't anything when pushed (it just springs back out) so maybe it's been disconnected)... Apparently the dash lights come on when you turn the head lights on (I have a soft-top, and I can't get the dash lights to turn on no matter what I do, so maybe the bulbs are burnt out)...
Look behind the dash, use a mirror. What is connected to the back side of it? Cable or relay like a headlight switch?
I guess I was confused as to why you would consult a BJ owner's manual if you had a question about an FJ. And evidently........![]()
If you don't have a BJ, then I guess you will have to choke it.
Hi, can anyone tell me what this control (circled with red in the pic. below), in a 1974 FJ40, does?
Thanks.
If this is your dual fuel 40 it might be the pull cable to switch the mixer to gasoline instead of LPG.
I'll look into that tomorrow afternoon...
secretagent.
Nice avatar. Saw a couple of those upclose a few times...
Well, I couldn't see what's connected to the back of it using a mirror so I'm guessing it's probably a choke pull (since that's where the choke pull is supposed to be according to the manual)... The headlights are controlled by a pull on the left hand side of the steering wheel, and I'm guessing that the dash lights are just burnt out, which is why they don't come on...
Thanks for all the input,
Rob
