Wanted FJ40 gas door lock with key
Tank5
Edit: I have what I need and no longer looking.
I am looking for a working FJ40 gas door lock and key. I have the early style door that hinges down instead of to the side if that matters.
Send me a pm if you have one please.
i have you covered here Mr TANK 5
- i CAN also RE-KEY it to your factory K series KEY CODE to match your ignition and side doors too if you like ?
links below
100% NOS TOYOTA NON-USA japan parts !
turn around time is about 3 days , till shipping due t0 the busy fall driving season , if you rekey
matt :)
Thanks Matt, I have a lead on a local option. I will get back to you if that doesn’t work out.
links below
matt :)
Matt,
How can I get or what will replace the tiny washers on the hinge? Mine are missing and the door is wobbly as a result.
Matt,
if your NYLON rotational bearings are smoked or simply turned into DUST ?
then this is your only option below :
- i have tried to service this early door and its bearing / bushings , after a hour i violently chucked it in the trash bin .....
- there not just washers , there actually a SHOULDER type grommet or bushing , the small tubular section slides into the center tube assy it-self at each end
I need a lock cylinder for my 78 fj40 if anyone can help?
