FJ40 & FJ45 minitruck ps conversion bracket kits and accessories (31 Viewers)
Status
Not open for further replies.
no problem, anytime.
when buying an air filter, make sure you don't get one that's too tall or it'll hit the hood. they do sell some fairly shallow filters. greenfox has had one on his 40 for years and it works well. also de-clutters the engine some. ;)
when moving the alt to the passenger side, try to find a set of brackets of a 2f engine. make sure you buy the complete set, with the lower bracket, upper bracket, tensioner and other hardware.
you will need to lengthen the alt leads slightly but that's a fairly simple job. keep in mind that the charge lead is always "hot" so i suggest dis-connecting the ground wire at the battery while working on this part of the conversion........
hth
georg @ valley hybrids
Georg,
Received my pump bracket two days ago...very nice. Thanks much!
Richard
excellent, thanks again!!!!!
Georg can you pm me a price + shipping for the pump brackets please. 70503
Thanks,
Larry
yes, i do make these. i have not made any for the rhd rigs but i guess i could. the bracketry would be similar but i'd have to make a new welding fixture.
hey scott.
thanks for the reply. all the brackets i have right now are already welded up so this would have to wait until i get the next set cut. i do not expect to cut anymore for at least two weeks; rubithon is this coming week and the week after i'm completely booked out. after that i should be able to spend a couple of hours making a new fixture and welding one up for you.
georg
How about two Georg (RHD that is)? Unless your still thinking about doing something else for them.
i can/will make them for the rhd rigs but sourcing the ps boxes will be a pita. maybe we can get in contact with a shop i know down under and see what kind of deal they can make us on a few of the ps boxes. worth checking into......
i should be able to build the rhd brackets next week. pe me your phone # and we'll get this set up.
Hey Georg
Will be dropping by Fri , Got any PS box brackets ? see ya Mike
Got mine !
these puppies are stout !! Nice workmanship , Nice surprise ,you also get Metric nuts & bolts included ! Right Awnnnnnnnn Georg ! Thanks
thanks for the compliments mike!!!!! always a good time when the knorr bros stop by the shop. :banana:
G`Day Georg
am converting a RHD Troop to PS this one has Alt on left side & a/c on the right will your brackets work with the a/c ?
also do you fab the PS gear mount for the sag steering gear as well?
Cheers
Paul
Status
