FJ40 & FJ45 minitruck ps conversion bracket kits and accessories
Status
Not open for further replies.
Well put me down for 2 (if what you were talking about is a bracket to use the stock FJ60 2F PS pump bracket bolt holes to mount a saginaw pump)
mark
I have done some tinkering with the fj60 sag pump conversion. One obstacle I've run into is the pulley. I'd like to utilize a one piece, preferably billet aluminum, pulley similar to the one for the earlier 2F conversion. Getting these pulleys made for a reasonable price is an issue. Still trying to get more quotes. The cheapest I've found so far ( locally ) is $85 each. That's my cost at a minimum of 20 pieces.
Hth
Georg @ valley hybrids
Your install picture shows using a narrow pulley. Do you have any pictures of your wider pulley that you sell? I am trying to find a decent pulley for the wider belt on a 5/8" keyed shaft. I know Man-e-fre sells one but it is really expensive and the industrial ones are super heavy.
Georg:
Any progress on the bracket to use the stock FJ60 2F PS pump bracket bolt holes to mount a saginaw pump?
Honestly ......... zero progress. We're so back-logged with service work and conversions that I have not been able to devote any time to this project. But we have put a couple of other items into production ( like the 1hz/1hdt engine mounts ) and the 60 ps pump replacement bracket is inching it's way to the top of the "make these and make them easy to use" list.
Georg
Thanks... I have need for 2 of them so I can beta test when you need!
Status
