FJ40 and FJ60 - BRAND NEW - Dash instrument cluster WITH gauges! (1 Viewer)
Status
Not open for further replies.
Please pm me price for complete kit. Can you do it in KPH instead of MPH? Thanks
Are you working on a 40 or 60? Did you want Black or White?
Let me know and I will check on it.
Thanks,
Matt
We have been working with a manufacture that makes these dash kits for classic cars to develop a kit for the FJ40 and FJ60.
The dash itself is an ABS plastic, available in a textured Black or Smooth Brushed Aluminum look. Many customers paint them to match their interior or leave them as is. You have your choice of White or Black Faced Gauges as well!
These start out as a stock dash, laser scanned into software that allows them to recreate the dash perfect for the Autometer gauges. Then, they are vacuum formed and CNC Laser cut to perfection! As you can see from the pics, the gauges are also recessed into the cluster for a VERY clean look!
Those that want/need warning lights can add LED bulbs to the cluster or anywhere you choose. Most commonly we see two Green for turn signals and one Blue for High Beams.
The dash will install using the same mounting holes as your stock unit.
We offer a complete harness kit as well. This will plug into your stock harness and use many of the signals already there and also includes LED's for the turn signals and high beams.
The Autometer gauges come with sending units. We have GPS speedo senders if you want to go that way instead. They are great as there is NO calibration!
We have also introduced a Fuel Level sending unit OHM modifier. The stock sending unit in the 73-87 FJ40 and FJ60 is a 17-120. Autometer does not make a gauge that reads that range so our unit will convert you to 33-240! This makes this a simple upgrade!
All gauges are electric so you will need to install the Oil and Temp sensors in the motor, wire up the dash and if you are still running a stock cable driven speedo, let me know and I will give you some options.
Feel free to contact us:
Call: 866-628-8746 (8-4 Pacific, Mon-Fri)
TEXT ONLY: 925-989-9091
Email: Forums@mcbparts.com
Send a PM
Send me a PM and let me know prices of this assembly. Its very nice. William
are there pictures showing the full kit installed in FJ60's anywhere?
Yes, the manufacture did an install for pics for magazine ads. Here are a few I have... I saw that you are V8 swapped, this is exactly who we designed these kits for!
Status
