SOLD FJ40 (1978) H41 transmission w/case
New York
Really clean on the outside, no clue how it worked before I got it or I would be lying since it came from South America
asking $1,000 You set up the shipping
Will post pics later
Pics added
10 spline output shaft
How do you know it’s a 10 spline output?
That’s the tcase. The trans tailshaft is behind the cone shaped cover. If it has a crush/stake nut, it’s a 16 spline. GLWS
I thought it will be the same, Thank you for pointing that out as I do not nothing about this transmissions
d.
mark, sounds like you know everything a out this transmissions. Trying to figure out if for sure this is a H41 for a potential buyer here on mud. I have counted 39 teeth on the first gear, does this sound correct for the transmission type ?
d.
Why don’t you shift it into first gear and see how many times the input moves for one rotation of the output? It’s that simple.
So, did you test it?
