Wanted FJ40: 1/79-7/80 Smog hard pipe sub-assembly, 2 Green VTV, Smog pump pulley
wimberosa
Durango Colorado
  1. 40 Series
Need combo of following 3 items or separate if no combo. @65swb45 Mark your catalog is showing you may have item 1. If you've got all three items then perfect
1) Need 1 smog pump pulley of 3 hole pulley variety 1/79 - 7/80
2) Need 2 Green VTV part number: 90925-01029
3) Need 1 smog pipe transmitting sub-assembly part number: 17303-61010 Further description follows.
From 1/79 to 7/80 there was a bundle of small diameter hard pipes that distributed smog lines near the manifold. They are bundled as
one unit and are useful for routing and keeping hoses from melting when too close to manifold. Here is what it looks like in the catalog.
@pardion this is the correct Pulley and VTV....although I only need the pulley and not the air pump...so uncertain if you are willing to separate.
Your hard pipe sub assembly is from an FJ60 1981+... not the fj40 1979. You have the following hard pipe.
I'm going to give @cwags12 thru monday to see what hard pipe they have... Pinged me first.
Appreciate the offer of items and will get back to you.
@pardion Would you mind spinning this section around and taking pics from two more angles? Since this is not a 1979 spaghetti tube...I'd need to ensure I could rejigger it a bit with pipes going generally close to where I need them. This looks close...but I'm just not sure.
@pardion First of all thank you for the pics. Unfortunately I cant figure out the routing differences and whether 60 tubes can be reused for different purposes. The HAC system on the 60 and 40 look similar with an extra tube for the 60...so at least part of it could be similar. The ABV/VSV air injection looks pretty dramatically different because there is additional routing on the 40 over to a bvsc on the top hemisphere of the thermostat. The tube parts over by the thermostat look plausibly reusable but there are 4 extra tees in the lines by the carb/manifold fuel filter that I don't understand. I barely understand the 40 emissions manual. The 60 manual is a step beyond. I'm getting into new territory for re-use that I had not considered before.
I need to kick over new options for this tube routing. I could plausibly bend a simple version of what I need if I can't find a real 40 spaghetti tube assembly for the 1979.
Calling all spaghetti tube hoarders....I have an oddball tube assembly need for the 1979 FJ40
Are you willing to sell me the 3 hole pump pulley? Again...don't need the pump...as my pump is fine.
