FJ25 Tail Lights
EWheeler
GOLD Star
Menifee, CA
Spent the last hour searching, with no success.
Are smaller diameter FJ25 tail lights available from Toyota? I ordered a pair of these online, but I'm thinking these aren't what I am after....
8155060011​
2
$ 22.86​
LAMP ASSEMBLY, RIGHT REAR COMB
I want the red rear lights that are identical in size to the bib lights, I am going to recess them into an aftermarket SWBFJ45 rear bumper and want to have 6 lights total: each side will have red, amber, and white (stop/tail, turn signal, & reverse). I see SOR sells the early early lights for $90 each. Looks like they sell the red lenses alone for $50 each.
Any better source for these items? Thinking I just pick up the lenses from SOR (or somewhere else) as I picked up 6 of the bib light housing for $11 each on black friday. Will the SOR lenses work on the bib light housings?
Thanks all.
Evan
8155060011 is not what you need. To make a FJ25 tail light you need a bib light from Mr T (or one of the vendors) and a reproduction red lens (the red and clear reproductions were cast from the amber SAE67). Just be aware that the bib light uses a dual filament socket (1157) but only uses one of the contacts, if you want the use of the two filaments you'll need to solder in a second wire bu doesn't sound like you'll need it for your application.
Thanks for confirming. Sounds like I have everything I need except for the red lenses. (clear lenses were ordered from thecrazygreek a while ago)
