Yes I've searched.
I brought home a fjc 17" steelie. I put it on the front left hub. There was no tire on the FjC wheel. The wheel cleared the tie rod and the claiper.
It seems the reason for spacers is to get clearance over the caliper and the tie rod. Both are inside the (inside) of the fjc 17" wheel...so what's up with needing spacers?
Put another way...
In that I do not see running a tire wider than 10.5-11 inches, why would I need 1.25 inch spacers?
Are the spacers needed to stop rub in turns and/or flex? Or is everyone using spacers because they run 12.5 width tires?
I have an OME 2.5 inch lift and currently run stock wheels and 33X10.5/15 BFG AT
Put another way...
