Anyone have any laying around? I would like to have a set to possibly use on my new 45. No rush.
thanks
thanks
why not order them from toyota?
Pretty sure you will need spacers for those fjc wheels to fit.
There's a guy in Tucson selling original style steelies for $45 a piece with is not bad. Says he has some welded and some riveted wheels.
Usually the 16" Tundra/Tacoma (16 hole steel wheels) are probably easier to obtain than the 17" FJ Cruiser Steelies.. (BTW, no affiliation with this listing below)
5 FJ steelies w/BFG KO2 KO tires
Yea, that's just too much. I picked up my steelies from a custom wheel and tire shop back in SoCal for $20 each. But mine are 16" x 7" off of a Tundra/Tacoma. My brother has 17" FJ steelies on his 4Runner. I think he paid like $250. Not as common as the 16sI already have some spacers, so not an issue. What I want to do is try to mock up some clips and weld them on to retain the fj40 hubcaps. Not sure that will work. If not I would probably try the same thing on my 16" split rims or some 16" 4runner spare steel wheels.
I talked to that seller. He wants minimum of $400. For that sum I would have to place some value on his almost useless tires. These steel wheels are usually $25-$40 at the typical used tire places. If he was asking $100-$150 I would buy them just to see if I could FAB up what is in my head. $400 is too much for what I am looking at.
Thank you, Steve. I think if I end up going with 15" wheels, which I very well may, I will just buy some new ones. My understanding with these earlier riveted 15" wheels is that they won't clear disk brakes. God knows if I will ever do a disk conversion on either axle, but I should probably leave that option open in case I decide to do so.
Interesting how times change, remember when riveted wheel held very little value.
Sure you would agree, I remember when everything 40 had little value.![]()
