my water pump is toast, i'm replacing all belts but hoses seem good other than the clamps are corroded and I had to cut them for removal. The hoses have large indents in them from the ome wire clamps (possibly being overtightened by previous owner) and I am concerned if I go with standard hose clamps from Napa they won't seal properly. Any ideas on if I should bite the bullet and order new wire clamps from the dealer, not give a bum and put standard clamps on anyway, or replace all the hoses and then use standard clamps (being new they should seal with a different clamp). Also does the entire power steering unit need to come off in addition to everything else I've removed or can I just remove the studs and the waterpump unit should just drop out thus saving a step. (I've got many other issues besides the water pump which need attention also!)
