- Thread starter
- #21
Unfortunately I can't take on any work right now
It appears the mechanic doing the job didn't take all the inside bolts out. There's one behind the gear cluster. The transfer case has to be disassembled while in the vehicle first before the front part of the case can be unbolted. There is nothing but a paper gasket between the transmission and the transfer case and nothing that would prevent the transfer case from separating from the transmission.
It's a one day job. Only problem is, once you get it apart and you discover that the idler shaft is pitted and worn (common), you might have to wait a few days for the part to arrive from the dealer.
Sorry I don't know any local Cruiser mechanics.
PM Deo in Gainesville. He is "Mel Lowe" here on IH8MUD
He might take the job on.
Thanks for the info Steve.
I've ordered the rebuild kit from cruiser outfitters and it has the idler shaft included.
I seem to remember reading something on here about shims or something that also might be needed, but not always. Do you have any insight on that?
Thanks again
