My son's FJ 60 has the updated Weber carb and header. The vacuum idle advance vsv mechanism has been removed. The AC compressor won't engage unless jumped directly to power. Is the vsv necessary to engage the compressor? We have converted to a134, replaced the condenser, dryer, low pressure switch and used new orings. The system took nearly 20oz of freon but pressures sit at 25 low and 22 high @70 degrees. Jumping the compressor doesn't change this much. Could the problem be the amplifier? Can a compressor be bad even though it engages when jumped?
Thanks in advance for any help here. I'm my son's research dawg as I'm retired.
