JDM Hilux Parts
Hi everyone,
I am the newbie from the Island Barbados in the Caribbean.
I own a 1993 LN107 JDM Toyota Hilux. It is the fully loaded 4x4 double cab model that has the two battery, 12 volt electrical system.
I am looking for the wiring harness that has the connectors for the headlights and electric antenna on it (Not the cable connected to the antenna mast for radio reception).
I would also like to get the plastic battery tray for the driver side battery.
All of the information I have for my Hilux is listed below:
Model : S-LN107-PRMGS
Engine : 3L 2779cc
Frame No. : LN107-0014471
Color : 147 Trim : GM11
Trans/Axle : G52 G285
Plant/Built : P11
Engine no. : 3L-3341942
The electric antenna is mounted under the passenger side front fender.
The harness I need is routed through a hole in the body close to the antenna where it plugs into another harness just inside the cab. There is a rubber grommet that seals the hole it passes through to prevent water getting into the cab.
There is also a plastic grommet on the harness to protect it from damage, where it passes through another hole into the engine compartment, just behind the battery on the passenger side of the vehicle.
There are 3 connectors in this same area that plug into connectors nearby. The harness is then routed across the front of the engine bay just above the 2 headlights and is then plugged into a relay/fuse box on the drivers side.
**** I HAVE EDITED THIS POST AS I HAVE ADDITIONAL INFO THAT WILL HELP IN FINDING THE HARNESS I ***** NEED.
******** I HAVE MADE A NEW POST TODAY (02-21-08) WHICH DETAILS THE ADDITIONAL INFO I NOW HAVE. ********
