The 62 failed for high NOX in October. I just got around to testing the EGR system, and here is what I found.
When I applied vacuum to the EGR valve with a hand pump, nothing happened. Sounds like a problem, right? But when I ran a line from the EGR valve to the manifold, it killed the engine instantly. So, does this sound like it is operating properly to you guys?
Second, I tested the EGR modulator following the FSM. So I blocked off two of the ports and blew into the other. Air is supposed to move "freely" through but it took some effort. You are then suppose to ramp the RPMs up to 2.500 and then air is supposed to be effectively blocked. It felt the same at both idle and at 2,500 rpms. Culprit?
