Francis K
I'm in Livonia and there isn't a huge market for 80's in Michigan as much as other places at least so I was thinking this would be the right place to ask as I'm having trouble coming up with a fair price. I'm sad that I never got to bring her to any meetups but my circumstances in life has drastically changed, I've gone from a 3 mile commute to a 40 mile daily commute and while I plan to pick up a newer Toyota truck in her place it doesn't make much sense for me to be driving a built up 26 year old truck 80 miles a day minimum. I built her to take her on trails, go camping, fishing and all that good stuff but none of that has happened at all and it's not going to anytime soon.
She's not dolled up at all she definitely would clean up a lot better but I got some basic pics and I made a list of work done. I added a lot of small things but I wanted to be thorough, believe me I could have added a hundred more small things if I really wanted to. Here it is:
Completely baselined 2 years ago when I bought her, all fluids changed, greased, lubed and all that good stuff religiously. I keep an excel sheet for it, have been using Mobil 1 10w-30 and I undercoated her before each winter….used clear film not black to hide things. For being a Midwest truck she shockingly has no real underbody issues.
97 with roughly 245k
ARB Front
NWTI Rear
XO Fab Sliders
Re-upholstered Leather Front and Mid Seats Also Center console pad
Hi Lift Jack Mounted to ARB w/pad
Painted Carpathian Gray 2/22
New Battery 8/22
New Window Runs 9/22
EGR Delete Kit (original parts included)
ABS Delete Kit (original parts included)
New OEM Radiator and Hoses 9/22
New Thermostat 9/22
New Hood insulation 1/22
Door Jam switches replaced 1/22
Cooper Discoverer Including Spare 285/75/16 1/22 @ 238k
New Denso Starter 3/22
Toyota Premium Car Horn (from 200 series)
OEM Clear Corner Lights 3/23
Clear Signal Lights
LED Dual DRL and Signal Lights in ARB
Pioneer Bluetooth head unit with Rear View Camera
New Speakers all around
Keyless Entry Remote Start Alarm
Wired TPMS
ALL Interior lights replaced with LED (dash, controls, domes…everything)
Kut Snake Fender Flares
New Hood Insulation
Teq and 100 series Badging
Third row removed but I have them
Black Dash Trim Kit (only used partially)
Knuckles Rebuilt 12/21
New Tie Rods 12/21
New Advics Brake Master Cylinder 10/21
Traction Boards/Axe/Shovel Mounts
Differential Plug kit 12/21
New Dimmer switch 2/22
New OEM Air Filter
All Belts replaced 5/23 245k
Throttle Body/Manifold Cleaned 5/23 245k
Dobinsons 1.75” Suspension Kit:
C59-210V
C59-221V
GS59-683
GS59-682
SD59-824 (steering damper)
RB59-522K (caster correction bushings)
Known issues
I just had her fully inspected and the report revealed the oil pan is leaking as is the PS pump. I have the parts, a new PS pump and hoses, and I was going to get it done along with the other issues but instead have decided to sell. Parts are included
P0770 Code came on a few weeks ago, it never came back but I bought a new transmission solenoid anyway, also included
Wheels need to be balanced
I have an intermittent steering wheel squeak/rubbing type sound. Inspection showed it to be the rubber in the boot and was told there was no need to address it.
Common rust in corner of rear hatch window, I had this treated when she was painted but it’s there
Cosmetic crap:
Windshield buckeyes
Common crack in dash at center of steering wheel, not a bad one but it’s there
Rear badging is misaligned
Rear bumper needs to be adjusted, low on one side
Steering Wheel has a nice stitched wrap on it, I’ve never removed it I’m assuming it doesn’t look too good under there
Pics to follow...
ARB Front
NWTI Rear
XO Fab Sliders
New Battery 8/22
New Thermostat 9/22
Clear Signal Lights
Wired TPMS
New Hood Insulation
New Tie Rods 12/21
New OEM Air Filter
C59-210V
C59-221V
GS59-683
GS59-682
Known issues
Cosmetic crap:
Windshield buckeyes
Pics to follow...
