Parting Out Feeler -- 1996 Land Cruiser - 1FZ-FE motor + transmission + parts for sale
San Francisco / Zephyr Cove
Feeler -- 1996 Land Cruiser - 1FZ-FE motor + A343F transmission(Pretty sure it is the A343F) + parts for sale
Engine issues – I believe the bearing somewhere in the bottom end. Transmission had no issues but it probably needs to be rebuild (I was going to do it but I am changing the direction in what I want to do with my LC)
~240,000 miles
Engine was rebuilt with all genuine OEM Toyota parts. I have photos and receipts.
Fixed then Drove it ~1500 miles no issues and ran great (really great). Then something happened to the engine. I won’t know for sure until I pull the engine. I think it’s a bearing, the trucker (he has a race shop) who trucked it back home thinks it’s the bearing. I will probably go the LS route now.
Everything OEM new unless stated. Please excuse if I do not name something correctly – just posting this quick.
Cylinder head cleaned, no cracks, new seals (was taken to a machine shop)
Intake manifold cleaned – inside and out.
new radiator
new steering pump
new water pump
new main wire harness
vacuum lines replaced
new fuel filter
new distributor cap
new spark plug lines
new fuel injectors
new Fuel pressure regulator (on it not oem but I have the oem one just not installed)
new 2* knock sensors
new crank shaft sensor
new thermostat
new temp sensor
new cylinder head bolts
new spark plugs
new alternator (rebuild denso)
new park neutral safety switch
all gaskets and seals were replaced.
*not installed but New*
I also have a complete engine rebuild kit.
New fuel pressure regulator.
New oil temp sensor.
Rear main seal
denso rebuild starter 2.0Kw
Many other gaskets I will give more info on
More parts will add
*used came off original*
wire harness
water pump
steering pump rebuilt myself
6x fuel injectors (currently at fuelinjectorconnection)
transmission harness
spark plug wires
spark plugs
(nothing wrong with the water pump, steering pump, dist cap, spark plug wires, but I change it since I was there)
I may make a quick webpage to help organize everything.
If you have any question please PM me.
I would like to sell everything in more of a bulky fashion.
Engine and tranny are completely clean (that took longer than the rebuild). I will post photos and videos in a day or 2.
Hi,
I need the female part of the connector that is just behind the distributor. Please see attached image where I am showing the connector with a white arrow/wedge. Let me know if you have it. Thanks!
